How are you going to pull the wire out at the pull box after you get the rope out?  What are you going to do with the wire then?  The conventional way to do your pull, if the wire can't be pulled from one end to the other in one pull is to sett the reels at the pull box, and pull in one direction, preferably the long one.  Then in unspool the remainder of the wire, keeping it clean, and feed it in the other conduit.  Does this explain a little, why 25 hours per thousand?  Generally for these underground pulls you wouldn't use sheaves.  My first mentioned method is a way to prevent wire laying in a muddy field .
