- Lockport, IL
- Retired Electrical Engineer
I would like to ask for information, experiences, recommendations, and whatever I can get on the issue of the use of aluminum (AL) conductors. The NEC has allowed AL conductors for a very long time. The Department of Defense (my present employer) publishes its own “building codes” in the form of “Unified Facility Criteria (UFCs).” The relevant UFC allows AL conductors above a certain AWG size. I am dealing with a military base that has adopted an even more stringent requirement: “copper only.” I would like to get them to reconsider that requirement. But it would help if I could present some supporting technical substantiation.
Questions:
Questions:
- Am I right in believing that AL conductors had a bad reputation in decades past, and that the technical issues included poor electrical connections, special requirements for making those connections, corrosion, and overheating to the point of creating a fire hazard?
- Am I right in believing that those issues have long since been resolved, and there is no longer any reason to be concerned over the safety of using AL?
- If use of AL conductors is safer now than in decades past, what has changed? Is it something to do with manufacturing (i.e., materials science)? Is it related to installation techniques?
- If AL is used for, say, service or feeder conductors, will that require periodic maintenance to ensure that the connections remain tight?
- Do you use AL conductors when you are given the option?
- Are you aware of any recent failures (e.g., fires) for which the cause was traced to AL conductors?
- What else should I know about AL conductors?
