- Illinois
- retired electrician
If they are unused, they are probably disconnected and not a hazard."If I said well that’s my bad it’s on the local lake. My dad has water rights and we lost power. Diver found a Beaver attached to the line. Says there is miles of Unsed wires in the lake and splices all over. I will not let my kids swim there is a death trap".
But in general it is not safe to be in water where there is electrical equipment in that same water. Nothing, other that a neutral isolator can make it safe from one of the most common issues, that being elevated Neutral to Earth Voltage. It is often very difficult to get the utility to install a neutral isolator
The only reason a code compliant pool is relatively safe is because the code required bonding raises the voltage of the water and everything that can be touched while in the water to the same voltage eliminating any potential differences. That is not something that can be accomplished on a lake or river.
