I'm having trouble deciding the cleanest/best way to run the feeders from a soon to be installed ATS back to my main panel that is directly behind the meter base recessed in the garage wall.
ATS is 10 inches shorter than the main panel. I was originally was going to nipple out the side of the ATS and LB into the top back of the panel but that's not really an option in regards to where the available knockout is.
I was thinking of using an LR out the bottom of the ATS and then an LB into the wall under the Meter/MDP and putting a trough/pull box below the main panel. But I can't find any that have an oversized flush cover as this is a finished and painted garage wall.
Any thoughts on the best way to do it?
