BHastings
- San Diego, CA
I am a contractor in CA and we just these lists of banned electrical panels and breakers from a condo HOA.
First carrier gave this list:
The second carrier gave this:
There is no need to talk about FPE at all.
The same with small frame Zinsco breakers.
Now Zinsco did not make their own large frame breakers, there is a lot of switch gear and meter distribution panels with GE breakers. I don’t think these were ever part of investigations into Zinsco’s issues. I don’t think a Zinsco placard on one of these sections of gear should make that assembly bad.
Going into old buildings and pulling out old gear with new will 98% of the time never fit in the old electrical rooms.
I have not seen issues with Bulldog products other than they often don’t like to reset, but never from a failure to trip.
But if you are now going to ban:
ITE Siemans
Challenger
Square D
I was shocked to see Square D make this list.
This is the 6th HOA or property management group that has come to us in the last 4 months concerning both residential and commercial properties.
We are left with:
Eaton gear, panels, and breakers.
Old Westinghouse gear.
Leviton panels and breakers.
Small regional independent manufacturers?
Your feed back is greatly appreciated.
"As long as you are reviewing the building equipment, these are the circuit breakers with high failure rates:
Federal Pacific Breakers/Stab-Lok
GTE/Sylvania products (some)
ITE/Seimens/Bulldog Pushmatic
Zinsco, including Zinsco compatible breakers such as Kearney
It is also important to confirm that your structure also does not have the following:
Non-pigtailed aluminum wiring
Square D Panels
ITE Siemans
Challenger
Square D
We are left with:
