mikeames
- Gaithersburg MD
- Teacher - Master Electrician - 2017 NEC
Your redefining the word near to fit what you want. Near means a short distance. A switch behind a door is near. You are defining a specific path and distance to circumvent the actual meaning of the word "near". If you want those limitations then just say opposite of the hinge side and within X inches of opening.This I'll disagree with.
For this particular application, we could define "near" as meaning say "when the door is open 90 degrees, the length of a string connecting the tip of the switch to the center point of the doorway shall not exceed 3', where the string may not pass through any opening smaller than 6" in diameter." If we had such a definition, and the door has no holes in it, and is at least 18" wide, a switch behind the door can never be "near".
Of course, as the NEC does not provide that definition, it is debatable whether the AHJ has the authority to interpret "near" as meaning something like that which would rule out switches behind doors.
Cheers, Wayne
I read your explanation and its got 6" holes, 18" of width, Not exceeding 3', and strings passing through openings.
In general, I am against a change requiring that. I don't think its something the code needs to spend time on. If so then there are many other wormholes the follow. I think the customer will enforce this as necessary regarding safety and or convivence.
