ramsy
NoFixNoPay Electric
- LA basin, CA
- Service Electrician 2020 NEC
WWEST 110v Class II RCD may work better than GFCI & AFCI, but its a din rail companion not adopted by North American OEM's.At the moment of contact with a live part, the person will be hit by a full electric surge and it makes virtually no difference if a residual current device with a sensitivity of 5, 10 , 20 or 30 mA is applied.
www.ecdonline.com.au/content/electrical-distribution/article/rcd-innovation-promises-electrical-safety-improvements-1097502870
The same industry that leverage their NFPA code-panel appointments, to adopt 2-Pole GFCI's, AFCI's, and SPD's, will likely block RCD devices, with intellectual property owned by competitors.30ma GFPE breaker would provide all the protection needed to protect persons from shock, and, based on their papers, I think the MFR's think so too Eaton, Siemens and ABB alredy make RCD's and GFPE breakers.
