I have a driven ground rod with a single #6 Cu conductor to it from the service disconnect.
Inspector is requiring a second ground rod be added to the system.
He said it needs to be continuous #6 from the disconnect to the second rod.
I said that the second rod only needs a bonding jumper between it and the first one. It can be attached with an acorn clamp and go the second rod.
I believe I’m correct.
Am I?
Thanks
Am I?
Thanks
