journeyman0217
- Tennessee
- Electrician
It is tapped to #4 468v...getting 472v on the meterIt is a delta-delta transformer and has no center tap according to posted nameplate. there are voltage adjustment taps on the high voltage side. If OP is having low voltage issues the tap being used could possibly come into play. Being reverse fed situation he probably should use one of the mid range taps though.
