ggunn
- Austin, TX, USA
- Consulting Electrical Engineer - Photovoltaic Systems
Crossthreading alert!Shouldn't that be fewer than three wires?
Relative to what? Take a piece of paper, rotate it to a random orientation, and draw a single line on it. What is the angle of that line?isn't phase angle the arctan(img/real) at any given point in time?
No. :happyno:Don't you mean "...just to see how much they could get on board."?
Over on Dictionary.com is a blog about just this issue.No. Just correct.
Victor - February 3, 2015 - 9:27 pm
Thanks! That is now one *fewer* mistake that I’ll be making from now on! Or is that one *less* mistake?
While I was pleased to see that Dictionary.com had given both sides to this fewer vs. less absurdity of a “rule”, I was deeply disappointed by the fact that the vast majority of the comments came from prescriptivist grammarians giving Dictionary.com an approving nod for mentioning their sacred “rule”.
The fewer vs. less “rule” originated from a grammarian in 1770 who merely expressed an opinion that he preferred using “fewer” for countable things while the vast majority of people had been using “less” for countable things. As with many prescriptivist grammar rules, someone transcribed that opinion into a book and suddenly it became standard.
Quite simply, using “fewer” or “less” for countable things is strictly a personal choice. Just don’t be ridiculous about it and say awkward constructions such as “I ate fewer than two sweets today.”
Did they have a listing for "burn"?Over on Dictionary.com is a blog about just this issue.
http://blog.dictionary.com/fewer-vs-less/
Comment on that blog:
Which confirms that my comment was correct.Over on Dictionary.com is a blog about just this issue.
This long history of usage accounts for supermarkets posting the words “10 Items or Less” over the express lanes, when “10 Items or Fewer” is the grammatically correct option
Phase angles are relative. If all you have is a single wire for a three phase system I maintain that it makes no sense to call out a phase angle for that conductor. It is 120 degrees ahead of one of the other conductors and 120 degrees behind the other, but without something to reference it to, a phase angle makes no sense. If you draw a vector out in space with no coordinate system to reference it to, it has no angle.Img to real
orientation does not matter
that is the phase angle
:?Did they have a listing for "burn"?![]()
Not from where I sit.Which confirms that my comment was correct.
As in: Duuude! Burrrrn!
Probably not in that sense of the word... but that's just a guess. :happyyes:As in: Duuude! Burrrrn!
Then might I politely suggest that you read the quote I posted which is from the definition you kindly cited?Not from where I sit.
You forget... that quoted comment was written by a person representing Dictionary.com. That person is no more credible than you or I when it comes to the adoption of English grammar rules.Then might I politely suggest that you read the quote I posted which is from the definition you kindly cited?
I agree.But we ought to return to the topic.
With just the voltage between two lines there is no voltage phase shift to measure. Thus it is single phase. Whether there a phase shift between current voltage because of a non-zero power factor doesn't alter that. It's an irrelevance.
But it concurs with the J. C. Nesfield manual of English grammar and composition that sits on the shelf above my desk. Along with the Chambers Dictionary.You forget... that quoted comment was written by a person representing Dictionary.com. That person is no more credible than you or I when it comes to the adoption of English grammar rules.
Personal choice does not ascribe validity or accuracy.Additionally, this is just another cascading of "As with many prescriptivist grammar rules, someone transcribed that opinion into a book and suddenly it became standard." I'm not saying you are wrong for subscribing. I'm just cascading "Quite simply, using 'fewer' or 'less' for countable things is strictly a personal choice."
I agree.
I'd take these as more credible sources than you or me.
Credible only in cascading the original opinion, not in the validity or accuracy of that opinion....
I'd take these as more credible sources than you or I.
Is zero less than one? ...one less than two? We all know each to be true. So to ascribe to the 'rule' is to say the conclusion just stated is invalid.
