jwelectric
- North Carolina
If not a pressure bladder, how about a compression spring in the the pump shaft that will keep the pump motor from over-loading?
why not just a plain old single phase center tap transformer
Well now I'm confused and curious. I love to learn new things and I am hoping you would be able to enlighten me. I have models for inductors using large paddlewheels with inertia, models for capacitors using bladders, and I would like to get the diode right.your check valves are not in the right order for the flow to work as you say it is working.
Then the piston will never move---ever.
If you really wanted to do this, you would have your check valves in the face of the pistons.
Thanks for the input. I'll look at that and see about refining my hydraulic model.By the way, with the heavy black arrow (triangle) some people will confuse this for a flow direction on the pump and not realize that your pumps are simply pulsating back and forth. It's this pulsating that messes up the concept you wanted to show by putting your check valves where you did.
Not at all. Just that you are invoking irrelevant rules when you bring in Flemming's left and right hand rules.Are you really saying the principles of electro-magnetism do not apply to a transformer?
I tried that and it did not seem to work for some because they are confusing direction with polarity.why not just a plain old single phase center tap transformer
Conventionally, it's the other way round but not important. The significant point is that the current and voltage from each end is displaced from the other.With the circuit that Besoeker has, the load current in the winding halves will only flow from the center to the ends of the windings and will never flow from the ends towards the center-tap. One half will flow in one direction and the other half will flow in the other direction.
As long as we are being irrelevant, a complementary right hand rule is:Not at all. Just that you are invoking irrelevant rules when you bring in Flemming's left and right hand rules.
I don't think anyone will automatically contest the concept that you could have two independent sources that are physically 180? out of phase, but you have to be extremely careful with your wording of it in the process. Forgive me for not taking the time to find a specific example for you, but that's because I am not trying to argue this, only point it out to you as the author. That being said, there have been times when a single word in a sentence has been enough to flag the entire sentence as incorrect. In other words, be careful with the "absolutes" that result from a single misplaced word.Rick at least agrees that you can have two real voltages with 180? displacements serving a single-phase three-wire circuit. His problem is with me saying that there are actually voltages in the center-tap winding that have a 180? difference. I understand that is his issue with what I have said.
Well, I had a 50/50 shot at it.Conventionally, it's the other way round but not important.
I believe it is the fault of becoming accustomed to thinking about things in one way for so long that one forgets there is a different way that is also valid. But what boggles my mind is the dispute after so much discussion, especially from those who know the theory. They are just mis-applying the theory.It beggars belief that such a simple circuit is still being disputed.
No doubt about that and we have burned a lot of posts for that very reason.I don't think anyone will automatically contest the concept that you could have two independent sources that are physically 180? out of phase, but you have to be extremely careful with your wording of it in the process.
This would be so much easier and faster in person. The problem here is what you mean, what you write, what someone reads, and what they comprehend can all be different and it makes a forum like this an interesting exercise in communication. These discussions have really helped me in writing things at work because I find myself reading things back and wondering how many different ways it could be taken.Forgive me for not taking the time to find a specific example for you, but that's because I am not trying to argue this, only point it out to you as the author. That being said, there have been times when a single word in a sentence has been enough to flag the entire sentence as incorrect. In other words, be careful with the "absolutes" that result from a single misplaced word.
When you are "catching the flux", with your right hand, motion is in the direction of your thumb and your outstretched fingers point in the direction of the current.
.mivey said:Since current flows from a higher to lower potential
It goes back to the basic definition of what a voltage is. I'll work on some wording for a post that hopefully will help you understand what I mean.Then explain how, in the real world of electro-magnetism, the direction of flux does not impact the direction of the voltage, or at least the high potential and low potential ends of a conductor.
First the 120 voltages that are formed from a center tap single phase transformer is not two sources but only one source, the transformerIs that your issue as well or do you also have issues with the voltages from two sources having a 180? difference, as in my post #98?
Now as to the direction of current flow like you said the current flows from a higher potential to a lower potential therefore the potential does dictate the direction of flow. You say we are confusing direction with polarity how do they not walk hand in hand.I tried that and it did not seem to work for some because they are confusing direction with polarity.
There again is the problem. When I try to get some fundamental understandings about voltages out of the way, you completely ignore that and jump right ahead to the main course. How about you finish the appetizer first then we'll move on to the main course? If you do not understand the part about the two separate sources, you will not be able to follow along in the next part of the discussion and we will constantly be going back and forth to discuss voltage fundamentals.First the 120 voltages that are formed from a center tap single phase transformer is not two sources but only one source, the transformer
Second these two voltages are not 180 degrees apart but instead all of one accord. Each is one half of the one 240 volt power source just as there are two 1.5 volt batteries in my 3 volt mag light. Should I decide to I could power two 1.5 volt bulbs one from each of the two 1.5 volt batteries. This does not mean that one battery is flowing one way while the other is flowing 180 degrees in the opposite direction.
Perfect example of why you need to finish the appitizer first or you will never be able to move forward. Go back and read my post #98. You will see that the polarity markings of the two transformers would be on opposite sides of the three-wire circuit. Also look at how I applied these two separate sources, with 180? displaced voltages and fed Rick's example circuit in post #290. Can you follow those two posts and do you agree that these are real voltages and not just math tricks?Now as to the direction of current flow like you said the current flows from a higher potential to a lower potential therefore the potential does dictate the direction of flow. You say we are confusing direction with polarity how do they not walk hand in hand.
Hold out your hand with your thumb pointing up and fingers extended, with your hand oriented like your were going to catch the flux in the palm of your hand. Then the flux goes perpendicular through your hand, hitting your palm first.
When you are "catching the flux", with your right hand, motion is in the direction of your thumb and your outstretched fingers point in the direction of the current. Gives you fewer finger cramps than Fleming's rule.
Polarity dots at opposite ends of the core comes from the minus sign in Faraday's Law of Induction.I know this has to do with transformers that have the polarity dot at opposite ends of the core instead of on the same end?
They mention flux, current and motion. Not voltage.Why are they irrelevant? Aren't they used to demonstrate an interrelationship between flux and voltage?
I am trying to point out that there are fundamentals that our industry uses when constructing and interconnecting electro-magnetic devices. Have you tried to build any of your mutli-pulse rectifier circuits by ignoring the relationship of the different transformer windings and the fluxes?
