Bulldog1401
Ohmage
Ohmage
Mr. stolz, did you mean2500ohms?
Ohmage
But basically for today's grounding (earthing, such as driving a ground rod) still doesn't do anything we (or at least I) thought it did to make anything safe in a home, establish a zero reference, or any of the other myths we carry on ([URL="http://www.mikeholt.com/mhgvb)."]http://www.mikeholt.com/mhgvb).[/URL]
georgestolz said:Yes.
And it's just George.![]()
Rockyd said:George, Bob, Roger, Thanks for help in links!
Bulldog, these people here are really not taking a side against you, we're trying to get you "outside the box thinking" for critcal thinking and evaluations. There is quite a bit of reading at the available links provided. I can't speak for everyone, but bet that this is the general concensus here, it's not about who's right, it's about what's right, and I happen to agree with them a good percentage of the time. Reason being is the amount of time that they put into reasearch of the industry in various fields of electrical theory and current thought.
The text in the NEC does indeed say that, if you don't acheive 25 ohms or less with one rod, then you need to drive one more. It does not say that you must acheive 25 ohms or less with the additional rod(s).Bulldog1401 said:I interpet that the one additional electrode had better be able to supply 25 ohms to ground, so you are required to use at least one more, multiple if you choose, but if you only choose one style it is O.K. Then just make sure it is effective. Don't just say good enough, and walk away.
Yes, there are, but most of the effect is temporary. If you believe that the need for a low-impedance electrode system is important, then surely you agree that the need goes beyond simply passing inspection.There are products available to treat the soil in the immediate location of the electrode to achieve this reading.
While we are all entitled to our opinions, it's unfair to say that the vast majority is confused because they don't agree with your interpretation. How can the author(s) of a rule be wrong, if their work is the rule?I see after reading the code making panels actions provided by Mr. Stoltz that there is confusion all the way up the line on the requirements. Time to overhaul this section.
chris kennedy said:Congratulations on the 5 star thread gentlemen.
Side note: Do I have to slit both wrists or just one?
... like discussions about religon, politics, etc.stickboy1375 said:Best part is this thread didn't even accomplish anything...
LarryFine said:... like discussions about religon, politics, etc.
If the goal is to change the opinion of the other person, it's a lost cause from the get-go.
stickboy1375 said:I know Larry, It just seems the simplest code questions end up being the longest threads...
Dennis Alwon said:You mean like "should the ground terminal on a receptal be up or down"?
Or should the screw in the plate be vert. or horizontal?
:grin: :grin: :grin: :smile: :grin: :grin: :grin:
ceb said:Yes, it did. If you drive a 4 ft ground rod here in NC,boy,and you get caught it will cost you $500.00:grin: :grin: :grin:
stickboy1375 said:Or, 3-way switches all down the load is off? :grin:
