GuruLal
- North Carolina
- Engineer
I recently had a solar PV system installed in my home, and I'm concerned about potential NEC 2017 code violations. The grounding conductor of the solar system, which is bonded to neutral, is inadvertently connected with the equipment grounding system of my house for my HVAC/Gas lines etc.
A MCT cable is essentially snaked through my attic space into the roof where I've got solar panels. The MCT cable is un-insulated. So the outer uninsulated metal conduit acts a neutral rod, since it is directly connected to neutral wire outside.
This has led to noticeable stray currents and a voltage difference between the ground of my home's outlets and a true earth ground. Additionally, I've observed magnetic field coming from outside the uninsulated metal conduits, raising concerns about the grounding and bonding methods used. I'm seeking clarity on the proper grounding and bonding procedures outlined in NEC 2017, particularly in Article 690, to ensure the safety and efficacy of the installation. I live in the state of North Carolina and they only recognize NEC 2017 as the last approved code by the state. Please help me in identifying where the code violation occurred. See my chicken scratch diagram for how everything is connected and located in the home. This contractor is doing this type of installation day in day out and I believe they are violating the code and installing this in an unsafe manner, esp when the grounding conductor of the solar panels comes into contact with homes other equipment ground way before it is bonded outside. GFCI's wouldn't be able to stop this either.
I uploaded the picture on the following link of my homes setup
https://ibb.co/B3FQk9Y
