Lighting Outlet. An outlet intended for the direct connection of a lampholder or luminaire
Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
Power Outlet. An enclosed assembly that may include receptacles, circuit breakers, fuseholders, fused switches, buses, and watt-hour meter mounting means; intended to supply and control power to mobile homes, recreational vehicles, park trailers, or boats or to serve as a means for distributing power required to operate mobile or temporarily installed equipment.
If someone wants to use the argument that "fused switches" are included in the definition of "Power Outlet" they are also saying that the screw holes and metal for mounting the metering equipment is an outlet as well, and regardless, it is specifically refering to "fused switches"
Receptacle Outlet. An outlet where one or more receptacles are installed.
Receptacle. A receptacle is a contact device installed at the outlet for the connection of an attachment plug. A single receptacle is a single contact device with no other contact device on the same yoke. A multiple receptacle is two or more contact devices on the same yoke.
