...........And the outlet,I don't think there is an inspector,no hand rail to lower level and the stairs going up are some architect's interpetation of "A Stairway To Heaven."They would never pass anywhere I have worked.
True, but not relevant. Here is why:
It need not be glass, but it does need to be a room divider. Remove the glass thingy. Stand on the second floor, right next to where it used to be. Behind you is a room. In front of you is not a room, it is a void. Step into the void and you get hurt. Put the glass thingy back. It has not divided a room into two areas, and it does not separate one room from another. It is not a room divider, so this article does not apply.
One can walk through AIR, not a wall.I got one for ya, what about a 'wall of AIR' lol. so is a receptacle required??
Nice turn of thought.Doesn't the glass divide the room and the stairs?
What if this glass was dividing the room from a closet?
I'm not convinced that in order to be considered a "room divider" it must divide within a room, or a room from a room. The whole point of the glass is to divide the room from the stairs (presumably for safety).
Imagine if you added a closet to a old room without one. Now make it with glass. Maybe a sort of stylish built-in book case closet in the corner of the room. Would the portion of the glass that sticks out from the wall 2-3' be considered "wallspace"?
Or, if the opaque "vertical thingy" in Pierre's OP photo (the stairwell back wall), has a Bath on it's other side. . . .Some are claiming the glass to be partition, so how can I not claim the opaque "vertical thingy" to be partition, AND, therefore, the Bath and the Livingroom are really all one. . .
etc., etc. A wall around a Bath area is not required. . .what if it has glass "vertical thingys" around it as well. . .
Inside or outside doesn't help distinguish what a wall is, as there are clearly "inside" walls as well.
Article 100 definition: Clothes Closet - A non-habitable room ...
Therefore your glass divider between the bedroom and the closet is separating two rooms.
.........The argument here isn't whether a receptacle is required. The argument is what name we give the divider. The name determines what is required.
If I get pulled over for speeding said:not[/B] speeding. I was qualifying."
That only counts for exterior walls.If the fixed side of a sliding glass door is considered wall space, I would consider this wall space as well.
While reading the NEC article in question, you don't get to the words "Any space," without first coming upon the words, in the article title, "Wall Space." The rest of that article tells us,One can't go over or under or through this "vertical thingy" and it is included in "Any space" wider than two feet, which, in my mind, is simply a wall.
(3) There are two specific instances of thingys that aren't walls, but that are to be counted as wall space anyway. [/COLOR][/SIZE][/FONT]
So if I have something that (A) Isn't a wall, as this thingy is not, and (B) Isn't one of the two non-wall-but-counts-as-wall-space-anyway thingys, which this thingy is also not, then I get to walk away from this article without doing any installation work.
Thanks. I was hoping to trade linguistic elegance for clarity.I like your hyphenated wording.
True. But the "such as" is not how the sentence begins. It is talking about a fixed room divider for which a free standing bar counter is one example. It is talking about a fixed room divider for which a railing is one example. But the subject of that particular sentence is the fixed room divider. If you don't have a fixed room divider, you can stop reading the sentence at that point, for the remainder of the sentence does not apply to your situation.#3 states "such as" which means that at least one thing other than the two mentioned could also apply.
True. But the "such as" is not how the sentence begins. It is talking about a fixed room divider for which a free standing bar counter is one example. It is talking about a fixed room divider for which a railing is one example. But the subject of that particular sentence is the fixed room divider. If you don't have a fixed room divider, you can stop reading the sentence at that point, for the remainder of the sentence does not apply to your situation.[/SIZE][/FONT]
That is what I am hoping comes out of my proposed code revision. I think I'll look on-line, to see if the cognizant CMP has published its ROC yet.It seems that there will never be total agreement without clear definition from the Code on the meanings of wall, fixed room divider, room, etc.
But what would compel the reader of the NEC to go to that source, when in need of a definition?BTW: The ICC is adopted in some areas, so the definition wouldn't be an issue of picking any definition that suits your needs... in those areas.
But what would compel the reader of the NEC to go to that source, when in need of a definition? [/SIZE][/FONT]
Well, this is what the discussion is hinging on.So if I have something that (A) Isn't a wall, as this thingy is not, . . .
