Electric-Light
This is the kind of stuff I run into. Not my pic, but I have seen hundreds of such failures.
That sure looks like slip joint bite marks. Among reasonable products, fool resistance varies but nothing is fool proof.
:thumbsup:Joints...
The thread seems to have moved on from crimps to wire nuts.
I think the important point in both cases is that they are properly in the first place. The pic in the opening post shows one that wasn't. That is no reason to wholesale condemn them to the trash can.
The one that has conductor pulled out - sure looks like something was used that was supposed to indent the barrel, but now that you said that the rest of the connections does look like regular marks from a standard pliers.That sure looks like slip joint bite marks. Among reasonable products, fool resistance varies but nothing is fool proof.
:thumbsup:
But the only way I would use one on solid is to insert at least 3 passes of the solid into the connector, effectively making it stranded.
The SS spring steel in a wire nut IMO is just to hold the twisted conductors together. Yes the instructions say just insert the straight conductors into the nut and twist until you see the conductors twist.
I've seen this done on #10 solid and in two cases the SS spring attempted to carry the current , overheated and melted the nuts.
Wagos in canned lights are OK if they only supply a single LED light. But, the two contact points in the connector having a very small area and are SS, which is a poor conductor. I would never use them to carry 20A.
To prevent oxidation inside a connector I dribble a little PVC glue into connector after I'm sure the connection is well made up. This probably violates Code but has served me well.
Not applicable to this thread, but yes, there is such a splice and I have made many hundreds over the years. It's solder with shrink tube.
You want it watertight, use a hotmelt glue gun on the Western Union splice, then slide the heat shrink on and use the heat gun, reflowing the glue as it shrinks.
A proper Western Union splice is soldered, and I use dual wall shrink tube that has hot melt adhesive on the inside.
I also have many different splices, all using various types of connections and shrink tubing, that are watertight.
As a test example, I have solid conductor out of a piece of NM crimped to male and female 1/4" spade connectors, no solder, and covered with my latest discovery of affordable dual wall tubing. It's rock solid and completely waterproof. I have been making waterproof connections for nearly 40 years.
In order to test the shrink tubing, I make the mechanical connections in various ways. Twist, solder, crimp, plug, with and without friction tape, vinyl tape, etc., and then see how much integrity the tubing adds to the splice. The stuff I am getting now is amazing.
Since you brought up hot melt, I will share one of my tricks. If splicing many wires, so that more than one will exit the tubing, adding hot melt where the wires will exit fills in the voids and also adds strain relief. Most people totally ignore strain relief when making up splices.
What's your preferred heat shrink product?
Did not mean to imply it was not soldered...of course it is!
I've not seen dual wall shrink tube with glue; supplier?
Most anything rated for direct burial applications is going to be this type.Did not mean to imply it was not soldered...of course it is!
Let me add my two cents to this subject.
A great heat shrink supplier. https://www.waytekwire.com/products/1381/Tubing/
I've used hundreds of crimped butt splices covered with heat shrink mostly 10 -22 AWG in agricultural buildings that have a corrosive environment. Some of the crimps are on 20A circuits operating heat lamps 24/7 to maximum circuit capacity. They've been operating for years with no problem. It simply makes wire way , breaker panel, etc., wiring look so much better than wire nuts. An improperly tightened wire nut can be just as bad as an improperly crimped butt splice. I'd say most failed butt splices come from improper crimping. I just make the effort to pull test each crimp splice I make.
Now if somebody could tell me where I'll find a ratchet crimper that makes quality crimps on 10-22 AWG insulated crimps, I have yet to find one. I've had the best luck with this.
http://www.kleintools.com/catalog/journeyman-crimping-cutting-tools/journeyman-crimpingcutting-tool
