Re: Big oops ... need suggestions
Originally posted by al hildenbrand:
I am not saying the current is taken from the switch.
No, but, unless I'm mistaken, you have been saying that current is taken
by the switch. That's where we disagree. I say that whatever a switch does, and wherever within or without the wiring system it does it, a switch does not utilize current.
If no voltage is dropped across the switch, then no power is expended within it, and no work is done. Thus, no current has been utilized. If the switch is open, the no current flows, and again, no power expended.
In other words, Ohm's and Watt's Laws infer that, with either no voltage or no current, no power is expended. Utilization of electricity (power, current, whatever term you like) requires some expenditure of power: motion, heat, light, etc.
One more thing: when a switch is open, no current is taken, even by your definition. Does a switch's qualification as an outlet depend on the switches position? A receptacle or other outlet does not stop being an outlet if the load is deenergized.
Thusly, a switch may control an outlet, but the switch does not qualify as one, as much as it wants to. I do not agree with the "takes and returns current" idea. Unless power is utilized at the switch, its enclosure, etc. isn't an outlet.
