Re: Big oops ... need suggestions
Al, since the last time I re-re-re-stated my view, you have had many chances to re-re-re-re-re-state yours.  To be fair to the membership, and to remind you that I have won this debate, I'll go one more time.
 You are saying a controller can be constructed with a switch and with no other component.  I have agreed with that concept.  But then you are using that concept, coupled with the definition of premises wiring system, to conclude that a switch is not part of the premises wiring system.  Next, you conclude that a switch "takes" current from the premises wiring system, and that it ultimately passes the current to the utilization equipment.  Finally, you conclude that the switch. or some point on or within the switch, or some point in its immediate vicinity, or the box that holds the switch, or something else that is within perhaps 4 inches of the switch's plastic handle, some aspect of "switchliness," is an "outlet."
 Here, once again, is the error within your reasoning:
 </font>
- <font size="2" face="Verdana, Helvetica, sans-serif">The definition of "premises wiring system" explicitly excludes, among other things, the WIRING WITHIN controllers.</font>
<font size="2" face="Verdana, Helvetica, sans-serif"></font>
- <font size="2" face="Verdana, Helvetica, sans-serif">There is no wiring within a switch.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Therefore, the definition of "premises wiring system" DOES NOT exclude a switch, not even a switch that serves as a controller.</font>
<font size="2" face="Verdana, Helvetica, sans-serif">That is sufficient proof.  But there is more.
 </font>
- <font size="2" face="Verdana, Helvetica, sans-serif">The definition of "premises wiring system" explicitly includes, among other things, "wiring devices."</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">A switch is a wiring device.  We don't need the NEC to explicitly define "wiring device," in order for this assertion to be true.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Therefore, a switch is a component of the premises wiring system, and does not "take" current from it.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Therefore, no aspect of a switch would comprise an "outlet"</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">QED</font>
