Wire-Smith
- United States
You would be surprised how many cable manufactures at the time were indeed interested in developing a standard for gas blocked cable. As I said, they dropped it because UL and the manufacturers couldn’t determine a suitable test that could be consistently applied in general.
EDIT ADD: As for a Code reference if you were attempting to apply one of the gas blocked Sections it would fall under Section 110.3(B).
maybe i'm misinterpreting your intention with the comment. but if 110.3(B) is to be interpreted as you can only install it for the use it is listed means every installation with a liquid tight box connector screwed into a condulet is a violation, duct seal inside a conduit(read the label, its for around the outside of conduits) (probably along with a ton of other common scenarios i'm trying to think of)
