Added: I'd have to say that it's not specified, but if I had to nake the decision, I'd say factory or equivalent. So, B.
I rarely see factory-threaded holes like the ones troughs and wireways usually come with for their covers.
Most screws can easily cut into the wire. If you have a wire pressed against the screw hole, you have other problems besides using the perfect screw.Based on i don't want a red tag on a final over something like this i would use a machine screw if i lost the ones that came with it. Sheet metal screws could easily cut into a wire. Now depending on the inspector i simply would not give him a reason to tag. Few would turn down machine screws if right size.
BTW, not all panel covers use machine screws.Based on i don't want a red tag on a final over something like this i would use a machine screw if i lost the ones that came with it.
OK Alex, I'll take Grounding and Bonding 250.8(A)(6) for a hundred.
Since when are panel screws considered "grounding conductors or a "bonding jumper" ? Im in 2008 and I dont believe they are either.
If the panel cover required bonding would it not have to have it from the factory to get a UL label?
Based on the originals are what they are because the manufacturer chose them. Nothing more, but what's a good reason for using a sharp screw?Again based on what?
I have never seen an instruction that said 'use our hardware'
Who designied those &%$& SQ D toggle bolt screws?
firstly 250.4(3) then 250.8(5) One could say 250.8(6) if those in the picture are machine screws, but alas for me, they are self-tappers and they do not create a secure bond IMHO and I won't use them.
Oh really? I dare you to attach a jumper from a 200 amp main breaker to the panel cover secured with those screws. Now close the breaker.
Iwire,
You can do whatever you want . I cannot understand why people would put two in and leave the rest in the bottom of the can. Seen it more than a few times.
