Re: Dedicated Circuit for referigerator
Follwing 220.16 (B) the 2002 Handbook states:
In each dwelling unit, the feeder load is required to be calculated at 1500 volt-amperes for each of the two or more (2-wire) small-appliance branch circuits and at 1500 volt-amperes for each (2-wire) laundry branch circuit. These loads are permitted to be totaled and then added to the general lighting load. The total load (i.e., small appliance, laundry, and general lighting) is subjected to the demand factors provided in Table 220.11.
Following 220.52 (B) the 2005 Handbook states:
In each dwelling unit, the feeder load is required to be calculated at 1500 volt-amperes for each of the two or more (2-wire) small-appliance branch circuits and at 1500 volt-amperes for each (2-wire) laundry branch circuit. Where additional small-appliance and laundry branch circuits are provided, they also are calculated at 1500 volt-amperes per circuit. These loads are permitted to be totaled and then added to the general lighting load. The demand factors in Table 220.42 can then be applied to the combined total load of the small-appliance branch circuits, the laundry branch circuit, and the general lighting from Table 220.12.
Being that I am lazy and had a bad night last night I will use the optional feeder and service load calculation for this lesson in the small appliance and laundry class.
In 220.82 (A) we are told that if the service is over 100 amps that we can use this optional calculation. We are to add B and C together or do B then do C and add the two.
(B) tells me to use 100% of the first 10KW and 40% of the remainder of this calculation
(B) (1) tell me to use three watts per square foot for the general lighting
Pay real close attention to this next one
(B) (2) 1500 volt-amperes for
each 2-wire, 20-ampere small-appliance branch circuit and each laundry branch circuit specified in 220.52.
In three we are to take the name plate rating of the appliances such as range ect
The microwave, dishwasher and disposal are all added at the name plate rating of the appliance, but should I decide to add a couple of extra small appliance circuits then I must add 1500 watts for each one of them. The same holds true for the laundry circuit.
This refrigerator that is being wired on an individual circuit WOULD be allowed to be on a 20 amp circuit with a duplex IF there was another 1500 watts added to the service calculation.
Those who use a third 20 amp circuit for the dinning room ARE required to add an additional 1500 watts to their service calculation.
[ June 26, 2005, 09:47 AM: Message edited by: jwelectric ]
