Solanaceae
- sangamon county, IL
It's not or about the chemicals in the lamp, it's mainly about the mining of them. Cadmium, arsenic, and gallium are obtained through ecologically disruptive strip mining. It doesn't only destroy habitats, but the toxic byproducts produced can seep into groundwater supplies. Sure, same applies for mercury, but it is more easily recovered from mercury gas discharge lamps than the rare earth materials are recovered from leds. I've also seen led lights here failing as often or more frequently than their predecessors they replaced. The initial cost for them was high, and the energy used was a bit less sure, but the savings are negligible due to the fact that you have to replace the leds again. The leds I've experienced just get trashed instead of sent to ewaste processing facilities, further adding to the waste stream. At that point, I'd prolly keep the magnetic ballasts that'll last a lot longer than going to leds that'll wind up as landfill food a few years down the road.
