gar
- Ann Arbor, Michigan
- EE
090402-1721 EST
Last night I installed the "TED" power monitor at my home. I am done with bench testing for now.
I really do not like the small thinly insulated wires that come from the current transformers. Mechanically I do not like their use in a main panel. Too easy to damage. Because I have 0000 wire into the main panel I had some difficulty in getting the transformers installed. There is no bending those wires.
I was running a residual load around 360 W last night, but it was necessary to turn some things off to get to this level. Prior to removing some load I was around 500 W.
Today I have run in the range of 1 to 2 KW. But I have kept some items off that normally I would leave on. From 1015 this morning to 1711 this afternoon, almost 7 hours, the DTE Energy reading changed from 10808.2 to 10819.0 and the TED reading changed from 9.6 to 19.9. The differences were 10.8 and 10.3. I had peaks greater than 2 and mins less than 1. 10.3/7 = 1.47 for an average KW load or 1.47 KWH average.
Their data logging software is called "Footprints". I do not care for their design, and I believe the graphing and printing parts have bugs.
Their live "Dashboard" showed a peak voltage of 127.2 V at 0155. There was no data recorded until
"2009-04-02 05:59:23","1.07","0","122.7" .
They showed a minimum voltage of 113.4 V at 1408. There was no data recorded at 1408. There was a gap of data between
"2009-04-02 13:56:57","1.53","0","123"
"2009-04-02 15:53:34","1.75","0","122.2"
because I was collecting on a different computer.
Using their program to export data from their *.db database file to a *.cvs file I got the above information.
On one computer I can not get data plotted from the database even though on that computer it puts data into the database.
I have errors on trying to print their manual for the software. They do not provide a printed copy. However, for the most part the manual does not solve my problems. Also I get errors on trying to print the graph. There needs to be great improvement in their software.
