091109-0911 EST
glene77is:
The freezer that I am currently monitoring is an upright and has the condensing coil on the rear and not in the side walls. It is fairly full and contains maybe 2 gallons of water in jugs, a shelf full of bread, two shelves of berries and greens, plus some miscellaneous items. Most of these items are not high density water containing product. Even though quite full there is not a lot of water mass in the freezer.
In particular the berry and greens products should not get too warm. At 60 deg F ambient the freezer cools from +2 F to -5 F in about 0.66 hours, and warms to +2 F in about 1.16 hours. The curve is approximately an exponential, but not really. The initial slope is about 4 deg in 0.33 hours, 12 deg/hour. Further up, between -1 and +2.5 the slope looks more linear, and is about 4 deg/hour. Suppose I ball park the time constant at 6 deg/hour to 63% ( (60+5)*0.63 = 41 deg change ). Then I have 6.8 hours to rise 41 deg from -5, or to +36. If instead the ambient is 100 deg F, then the rise is 105*0.63 = 66 deg in 6.8 hours or about 4.5 hours to reach about 32 deg F. But I do not want to get close to 32 deg.
My other freezer has cool time of about 0.33 hour from +4.5 deg F to 0 F and a rise time of about 0.5 hours. Both rise and fall are much straighter than the other freezer. This freezer is about 42 years old. It has less peak inrush current than the other.
There is a substantial thermal gradient in the freezer. So the meaning of the temperature measurement is dependent upon location.
I have no idea what the design criteria are for freezers and refrigerators. My goal in these experiments is to see what one can learn with simple instrumentation that may be useful to the average consumer in evaluating their energy consumption.
For power and voltage monitoring I am using a Kill-A-Watt EZ and a TED system. Temperature is measured with thermistors. Temperature monitoring may change to Dallas Semiconductor one-wire devices.
