RICK NAPIER
- New Jersey
The secret is to use surge arrestors not plain extension cords. Surge arrestors come in varies lengths with multiple tap ends and are not considered a temporary device. Just don't plug one into another.
It is my opinion that cords, unless they are physically attached in some manner to the building or structure, are not "installed" and are outside the scope of the NEC.
590.5 Listing of Decorative Lighting. Decorative lighting
used for holiday lighting and similar purposes, in accordance
with 590.3(B), shall be listed.
I did not word my post appropiately. Surge arrestors are tested to a different standard then extension cords and larger wire sizes are required making them more appropriate than extension cords. Here are the restriction on extension cords from the IFC 2009.
605.5 Extension cords. Extension cords and flexible cords shall not be a substitute for permanent wiring. Extension cords and flexible cords shall not be affixed to structures, extended through walls, ceilings or floors, or under doors or floor coverings, nor shall such cords be subject to environmental damage or physical impact. Extension cords shall be used only with portable appliances.
605.5.1 Power supply. Extension cords shall be plugged directly into an approved receptacle, power tap or multiplug adapter and, except for approved multiplug extension cords, shall serve only one portable appliance.605.5.2 Ampacity. The ampacity of the extension cords shall not be less than the rated capacity of the portable appliance supplied by the cord. 605.5.3 Maintenance. Extension cords shall be maintained in good condition without splices, deterioration or damage
605.5.4 Grounding. Extension cords shall be grounded when serving grounded portable appliances.
I am not so sure you would lose. It is very possible that the courts would throw out a lot of secions of the NEC including most of Article 422. There are panel statements on record that say the NEC ends at the outlet. But then on the other hand the court could see it the other way....
The only way I would be able to tell my inspector that section does not apply is to take them to court .... and I bet I would lose as the precedents have long been set with the NEC.
As far as the use of the extension cord having anything to do with my job passing inspection, it shouldn't unless my electricians installed it. I am not resposible for the actions of others.
I agree. Cords are personal property not real estate. Doubt if you could limit their proper use.
No, but the fire marshal can, and does, around these parts. Use anything besides a u.l. listed surge supressor to plug office equipment into and you will be "dinged". Then you can call me to install a new receptacle closer to your equipment. It works out pretty well on my end. I once installed 2 20a receptacles to replace a cord feeding two hot plates in a lab. I picked up the cord (100ft, 14awg, 90ft of it still in a tight coil) my fingerprints were melted into the orange jacket of the cord.
