But if it is feeder supplied, you wouldn't use it as service equipment is basically what my point was. Meaning you wouldn't install the bonding screw in the neutral and you would install additional equipment grounding bar if it didn't already have one. Grounding electrode would land on the EGC bar and not the neutral.
If you did install SUSE single breaker enclosure or a safety switch - same thing, you wouldn't install bonding jumper in the neutral.
You wouldn't install a non fused disconnect - unless you did find one that is SUSE and you were able to meet any additional requirements that went with that SUSE rating.
Buy a non fused disconnect and a field added neutral kit and ground bar, find a bonding jumper laying around somewhere, and leave it in a bag in the bottom of the disconnect and call it good.
JAP>
