- New Jersey
- Journeyman Electrician (retired)
If you don't want exposed condcutors then you'll need a junction box of some sort for the "taps". I would just use PVC for the GEC and PVC from each service disconnect into a PVC box. Split bolt the connections in the box.I dont mind doing this but can I do it inside of each disconnect with pvc pipe between each of the disconnects? I'm trying to avoid any exposed ground wires or a wire trough on the outside of this house
