That center rib of the panel cover holds the breakers "in place". I didn't mean to infer that it held a breaker securely in place. But, you can't remove the breaker with the cover on can you ?
BTW, I just remembered another reason why some inspectors won't allow interlock kits. I've had some tell me that they've seen instances where the main breaker did not disconnect from the utility when operated. "What if that happens ? "
IMHO, once you use that tiny little 2 letter word
IF, anything can be possible
- What IF the main breaker doesn't disconnect from the utility ?
- What IF the main breaker only disconnected one phase ?
- What IF a downed tree disconnects your triplex from the house and the POCO mis-connects when they power back up ?
- What IF a plane crashes in your back yard and you lose power ?
- What IF you won the $320 Mil lottery today and couldn't find your ticket ?
Anything is possible with
IF
