Nothing preventing a HO from connecting their generator to the range or dryer outlet with a male -male cord either. Somewhere you have to draw the line at what they may try to defeat. If you have a back fed breaker and interlock kit why do you need to remove the panel cover during a condition of running on standby power? All that is necessary is to turn the main off, move the interlock device, turn the standby breaker on.
Several years ago after a big ice storm, I had all sorts of customers that were not going to have utility power back for possibly several days, no transfer equipment, but a new generator they want to power their house with. Telling them they must have listed transfer gear and that it won't be installed for a few weeks was not the answer they wanted at that time. My solution for many of them was to disconnect their service entrance conductors, pull their meter, or whatever seemed like the easiest method so they can't backfeed the utility unless they intentionally make a move to do so, and then make a temporary connection to their generator. I was likely going to need to come back when utility power was restored to reconnect whatever I disconnected. We could then talk about what they want to do so an electrician doesn't need to be called anytime they have to run on their generator and when we may install it.
