K8MHZ
- Electrician
And I can't duplicate your experiment with my water, so asking me to show you by demonstration is really of no value.
Is the most important piece of information, that you believe you understand electricity, and GFCI's, better than most of the forum participants and moderators?
i never asked you to dupe what i did. i asked you to run your own experiment, even jump in if you like, do whatever experiment you see fit to prove a point, or disprove something i have done, etc etc.And I can't duplicate your experiment with my water, so asking me to show you by demonstration is really of no value.
i dont say this too often, its just one of those things i keep to myself, very obvious that many on this forum, including some mods, dont really understand electricity all that well.
here's an experiment showing you a possible scenario that a 2-wire GFCI will not protect you, and you are possibly dead.
the cord is a non-polarized nema 1- (i polarized it with silver marker). the hot has an inline ~18k resistor. the end of the cord has eyelets soldered on to attempt to mimic real terminations of an appliance. the sink is all plastic so no amps can flow out to a EGC, the water is warm tap water (my water is heavy in minerals and filtered via a water softener, more on this at the end). from the data, the "short" in the water (w/o the inline ohms) would not trip a 15 or 20A OCPD and the GFCI is as happy as a virgin for the 1st time. the stray amps across the unattached amp probes in random location in the water indicates that amps will still flow from wire --> across water --> into the body --> through body --> back into water, and return back to wire !! so as much as some of you think amps only take path of least resistance (WRONG), it takes all paths.
i dont care to explain this elementary experiment, so you'll need to understand it for yourself. in this experiment the amps through the unattached probes would not have been enough to kill, but the scenario shows the possibility exists.
voltage across end of wire no-load
short circuit amps
wires ends in water
amps of wire in water
amps probes just in water, not attached to anything
amps flowing through the unattached amp probes
shortest distance between the ends of the wire
as for water chemistry, the cleaner the water the more hazard there is. and depending on how the end of the wire terminates into the item, stray amps will vary (the closer the connections are to each other the less stray amps, the farther apart and bigger the connection then more stray amps).
hence, the reason why 2-wire GFCI does not cover all hazards, some potentially deadly. hence, the reason why all GFCI should be 3-wire. hence, the reason why all "bathroom" appliance should be NEMA 5- !!!
i leave the challenge of illustrating all possible currents paths in a liquid conductor to you, but let us know when you have it completed :thumbsup:a schematic of the experiment showing all possible current paths
are you saying that immersion is not one if the hazards NEC intends to try and protect against, especially in the bathroom area of resi ???And as I said, GFCIs were mandated at first to take care of open EGCs, not dropping a hair dryer into an insulated sink with both hands in it.
If immersion is that much of an issue there is an LCDI, and in the case of pools code requires you to "bond" the water.
Your own measurements, even if perfectly accurate, show one obvious reason the GFCI may not have tripped: they are at the cusp of the GFCI trip threshhold: 6ma. (6.79, 6.60)The last reading of 0.15ma is far below 6. Ofc its not going to trip then.
you really dont need to. use math from here.What I am thinking is that we remove the resistor from the cord and place one in series with the leads. This way we have a scenario which IMO makes more reflection of the real world. Appliances submerged are likely to have the terminals with no impedance between them and the plug, and the resistor will mimic typical body impedance.
well, i am sorry you had to write out all you did. so do this, rip out your wizzy-wig do-dad calculator, whatever that is, use the #'s i have provided, remove the inline resistor, run your math.
geez, i didnt think it would take this long for anyone here to figure out that the inline R is safety item !!! i perhaps didnt want to get bitten by 15A worth of juice with my hands in the water that has a cap cord jammed into a useless GFCI !!!!! you get it now ???? the inline R is meaningless in the context of the experiment !!!!!
the inline R doesnt matter !!!Safety? For what? Aren't we trying to replicate a real world danger where we will not have have an inline R?
the R doesnt matter !!!
and yes, safety, the GFCI is useless in this experiment, with 18k inline i cannot get bitten by 15A. but again, the R is meaningless, you get same end results w/ or w/o the inline R there !!
for some odd reason i knew this post would go south fast with lots of folks not understanding it.
anyways, feel free to experiment, jump in the non-GFCI'd water if you like to obtain some real human data. death is still real data, as long as someone is around to document it :lol::thumbsup:
geez, i didnt think it would take this long for anyone here to figure out that the inline R is safety item !!! i perhaps didnt want to get bitten by 15A worth of juice with my hands in the water that has a 1- cap cord jammed into a useless GFCI !!!!! you get it now ???? the inline R is meaningless in the context of the experiment !!!!!
let me get this straight:
you start off with mods/members don't understand electricity
and follow up with you won't explain it to us
ok
123 V / 18000 ohm ~ 6.8 mA
in line with your readings (6.79, 6.6 mA)
no EGC
so the current thru the gfci ct is balanced
did you expect it to trip?
why do you think if someone stuck their hand in the water (or same conditions in a bathtub) that the current would flow thru the water from the H, then into the body, back thru the water, to the N?
Do you really have your hands in the water with power on? That's a good way to win a Darwin award.
WRONG, those scenarios are not ignored, they can be categorized as being scenarios that may fall under the mA levels as obtained from the experiment, as i have already mentioned, please go back and re-read the 50 posts.Because he has isolated his experiment from all grounds, thus N is the only return path. He has also ignored the extreme resistance of the water further from the probes.
