Here's the bottom line: if you got your wish of 2 prong GFCI receptacles, the first time someone goes to plug in a 3 prong plug, they are going to use an adapter or change the receptacle to a 3 prong GFCI on a 2 wire circuit. There are stickers that cover NO EGC CONNECTED to 3 wire GFCI on 2 wire circuits.
we went over this a zillion times already, this exact statement of yours.
so lets think about the scenario with a tad more meat, shall we.
an old house that has old occupants, for last 52yrs in the home they never had any 5-R's (EVER), its all 2-wire crud. ok, so we can only imagine that for many many years they have used cheaters and broken EGC pins off, yes? ok, well, now you come along and swap out a 1-R with a non-EGC'd 5-R GFCI and place a sticker on it that says "no EGC". great, "20 more then" <-- sarcasm btw. the folks are blind as a bat but notice now there's this 3rd hole in the receptacle, they really have no idea what that is, but what they might know is, must be safer to just stop breaking off the EGC pin of items they buy, because you told them the GFCI is safer. well, they are indeed safer, but not because of the missing EGC, yet for some reason they believe that extra pin makes them safer, but in the realm of reality the 5- GFCI (now a logical 1-) does not provide all of the hazard coverage a EGC'd 5- GFCI does. given the context as to why anyone is swapping out a 1-R with a 5-R GFCI, why provide the EGC pin? imho, block it out, or, provide EGC. for those who thought the amps would only flow between the two terminals of the appliance when it hots the water, thats a big WRONG as many of us know it, but some insisted no amps would flow across the unattached amp probes, and what did we find, amps in fact do flow, and in some scenarios the amps through unattached probes can be greater that the trip specs of GFCI class-A !
Fiona,
First let me say I only read the first 40 or so posts then just skimmed over the rest to this point, so I apologize if I missed something other then people thumbing noses at each other in the previous 40 or so posts.
I am assuming you did this experiment because of a discussion that started in another thread, and I recall being the one that asked you to try such an experiment. I don't feel you succeeded at simulating the conditions that were being discussed in that thread though.
In that thread (from the best of what I can recall) you were claiming a person sitting in an isolated (from ground) tub of water would be shocked, and probably at lethal levels, if an energized appliance were dropped in the tub. I think most following there agreed that if the tub were grounded that a GFCI would likely trip, but your main claim that prompted the asking of you to do some experimenting was that in the isolated tub that current would flow out one supply lead, through the water, through the victim, back through the water and to the other supply lead (presumably at reasonably close distance from the first supply lead.
If you want to have a more accurate simulation and measure how much current the victim might see, get rid of the 18k resistor (it won't be there in the real world, and is a current limiter for what you have set up or for what I will suggest.
yes, its from the other thread that went south, so i provided some real experimental data.
you may have missed my reply in this thread about your comment in red. if the EGC is too far away (could be 4ft in a tub), the ohms across 4ft of bath water may be less than GFCI trip amps, so for those who agreed in other post, perhaps they were missing some data?
as for the part i bolded in purple, the inline R does not matter. if you believe it matters then please explain in detail why it matters. the inline R is a safety device, thats all it is. everything is linear in terms of V and A. if someone want to dupe my experiment w/o the inline R just to prove that it is linear, then have at it.
