I'm no golfer, but some guys have to run around more to find lost balls or get to errant shots, there is also those that play only 9 holes while others play 18. Why do all the carts have to come in at same time for charging? Some places maybe they do, smaller country clubs like I have been to they may come and go at different hours and definitely not all of them at same time.
Sure one can always figure what maximum demand will be and make that the minimum supply, but chances are you can get away with less then that - the larger the facility the more likely you can probably apply a demand factor - we just haven't determined what that may be.
Yes, I'm sure you could apply some sort of diversity factor and there will be comings and goings between sun up and sundown. But supply capacity will ultimately determine how many chargers you can have operational at the same time. I mean, can be you sure that all those in service won't operate at rated capacity simultaneously? I don't know.
Slightly off at a tangent......I wonder about the raison d'être for golf carts. I mean golf gets you out into the fresh air and walking. Play, say the 10th in four strokes and you would walk from the tee to the green. Good, healthy stuff. Then get in your buggy and go from the 10th green to the 11th tee...........
Kinda defeats the object - or I'm missing something?
