websparky
- Cleveland, Ohio
Re: Ground up or down?
Hear hear!
Hear hear!
Tom, as always thanks for your post, I wasn't aware of that. Question: Would you be in compliance with a metal faceplate and non-metallic screws?Originally posted by tom baker:
Leviton does sell non metallic 6-32 screws.
A snap switch wired under the provisions of this exception and located within reach of earth, grade, conducting floors, or other conducting surfaces shall be provided with a faceplate of nonconducting,404.9 (B) Grounding. Snap switches, including dimmer and similar control switches, shall be effectively grounded and shall provide a means to ground metal faceplates, whether or not a metal faceplate is installed. Snap switches shall be considered effectively grounded if either of the following conditions is met:
(1) The switch is mounted with metal screws to a metal box or to a nonmetallic box with integral means for grounding devices.
(2) An equipment grounding conductor or equipment bonding jumper is connected to an equipment grounding termination of the snap switch.
Exception to (B): Where no grounding means exists within the snap-switch enclosure or where the wiring method does not include or provide an equipment ground, a snap switch without a grounding connection shall be permitted for replacement purposes only. A snap switch wired under the provisions of this exception and located within reach of earth, grade, conducting floors, or other conducting surfaces shall be provided with a faceplate of nonconducting, noncombustible material or shall be protected by a ground-fault circuit interrupter.
Mike your still missing the purpose of nylon screws, that is just one use of these.Originally posted by jwelectric:
I have listened to a lot of renting and raving about the nonmetallic 6-32 screw here in this thread. Being that no one seems to understand where this screw mignt be used I will take a minute to tell you.
I found this one laying around.Originally posted by jwelectric:
?Picture of light bulb coming on over my head?
Originally posted by iwire:
[I found this one laying around.
Which is longer, a yard stick or a 3 ft. long 2x4?Originally posted by charlie b:
And while we're at it, "Which is heavier, a pound of feathers or a pound of gold?" (If you think you know the answer to this one, would you care to bet a beer on it?)
