kwired
Electron manager
- NE Nebraska
- EC
110.3(B) and I just posted Leviton's picture of how you are to attach a wire to the device. How is this different than stripping the correct length of wire if you are back stabbing the device?
If the conductor is continuous there is no end to have on the wrong side of the screw. The reason to wrap it clockwise is so if the end binds when turning the screw it has a tendency to pull into the screw. If it is wrapped counterclockwise and the end binds it will tend to be pushed out from under the screw.
If you are back stabbing the device there is no wrapping around the screw - what was the point of even mentioning backstabbing?
grounding screw that shall be used for
no other purpose
The grounding screw in the photo is not used for any other purpose but grounding. Where people most often violate this is when they put a grounding conductor under a screw that is also used for mounting the box or securing a device or cover.
If you have multiple conductors under the screw I may question if that is allowed but would not call it being used for more than just grounding, and that is another topic.
