peter d
- New England
Fuses.......
Busman actually makes a fuse panel that would work pretty well in a house. Square D makes a popular QMB panelboard, which features fuseholders, if you really wanted to get wacky. It looks sorta like an MCC.peter d said:Fuses.......
mdshunk said:Busman actually makes a fuse panel that would work pretty well in a house. Square D makes a popular QMB panelboard, which features fuseholders, if you really wanted to get wacky. It looks sorta like an MCC.
brian john said:Actually peter why not Zinsco?
2nd would be GE
Come on a million bucks?? And ill throw in a fluke ir thermometer just to check them.:grin:brian john said:CH I would not use GE on a bet, in my house.
My house already had CH when I moved in, and I have no complaints.brian john said:CH I would not use GE on a bet, in my house.
I like to trip them by hand with a good whack just to see the pretty orange flags. If you really want to shine someone on, you can write messages in binary on the shelf at your supplier.sparky59 said:i like the pretty color when a breaker trips.
Originally BRyant? The blue-handled tandems are the bane of my existance. All but the most recent years were flat-blade screwdriver only, and if you're just a bit off center you'll crack the casing off. The ones that had a pukey white casing are my least favorite of all.Minuteman said:I've been using Cutler's BR since back when they were called Westinghouse or Challenger. I've never had a problem with 'em.
LarryFine said:The cube relay controls a 4-pole, 25a contactor, which switches four of the 15a circuits. They supply (1) the switched electronics, (2) the 300w x 2 amp that powers the main speakers, (3) the 200w x 5 amp that powers the center, sides, and rears, and (4) the two 300w amps built into the main speakers, each on a 15" subwoofer.
: "You see, most blokes will be playing at 10. You’re on 10, all the way up, all the way up...Where can you go from there? Nowhere. What we do, is if we need that extra push over the cliff...Eleven. One louder." DiBergi: "Why don’t you just make 10 louder and make 10 be the top number, and make that a little louder?" Nigel (after taking a moment to let this sink in): "These go to 11."
