So is it safe to use #6 Romex for an EV Charger (or for any other continuous load device like a heater for that matter)?
What is the worst that could happen? Wondering if the PVC could melt and the wires could short and start a fire inside the wall.
An electrician is installing the wiring to support a 48A Tesla charger
today at my friend's house. They are using Southwire "
6-3 CU NM-B WITH GROUND" behind the sheetrock in the basement, from the main electrical panel to a service box on the outside of the house. Presumably this makes the job a lot easier (cheaper) for the electrician than using 4/3 NM or 6/3 MC behind existing sheetrock.
FYI - I'm interested in looking out for my friend's (the homeowner's) best interest here rather than the electrician.
The specification PDF (
https://cabletechsupport.southwire.com/en/cablespec/download_cable/?cable=26863&country=US) mentions both 60C and 90C. Does this mean that the insulation around the wires themselves (not the sheathing that wraps the 3 wires plus ground together) will be able to withstand 90C without melting but the sheathing could melt because it's rated for a lower temperature?
