GD found it, I couldn't find it earlier today and had to leave, but I knew it was in there somewhere. It is a general rule or all conductors in raceways, but the use of 6 solid bare for an EGC is where I see it violated the most. I think mostly because guys already have 6 solidbare for use with ground rods and don't want to purchase 6  green. If a larger EGC is needed they don't need green they can mark it green. I usually see it from pump panel to irrigation well motors when 6 AWG EGC is required, so length is usually 10 feet or less still a code violation - inspectors must not know or don't care is all I can figure. I always run a green stranded conductor.
