New member here, not from US of A.
You guys who are in the US or other countries dealing with AFCI, have you guys found any real evidence of AFCI have been preventing fire caused by electrical arc (AFCI tripped not because of "noisy" loads or real RFI or ground fault)?
AFAIK, on low voltage 240V or less, loose connections with resistive loads are more likely to produce electrical "spark" than electrical arc (unless there are carbon buildups), do AFCIs also trip when there's electrical "spark"?
Do some AFCIs also "measure" voltage waveform instead of only current waveform to sense electrical arc? I ask this because I've read some AFCI can be tripped from "noisy" loads in different circuit (or line side?).
