Honestly, I don't know what you are arguing here, but you went off on a tangent that I do not wish to follow you on.
My statement was that many of the excuses that people have made here saying that non-EC's shouldn't lay pipe also hold true for when it is an EC who lays the pipe. That's all I am saying, and I believe it is a logical statement, even if you disagree. If I read it correct, I believe even Roger agrees with that statement.
To say electrical conduit is not an electricians job to install is absurd.:dunce:
I never said that I agreed with it. NO, I do not want non-EC's installing pipe.
My contention is different as you can see from my prior posts.
BTW, laws shouldn't be made in order to give our own trade work (although I'll happily take the work if it leads to that!).
All of the arguments that say it is ok for the non-electricians to install the electrical raceways systems also would apply to the installation of the rest of the electrical system.
Same here, plus electrical and other utilities. This is especially true for the guys that do directional boring. Sometimes they bury a pipe and the end user pulls another pipe through the first one, other times they bore through the area and pull the actual pipe, raceway, etc. for the end user back through.Don that is an opinion, an area could decide that electrians are not needed to run conduit but are needed to terminate or any combination in between.
Here the phone company often uses excavation contractors to run underground conduits.
I don't think the OP is for real. There is nothing to back up the statement. Like links to something.
I've seen this before too, register and say something a bit off. Imo it's a waste of time. It takes away from the people with real questions.
People should participate in there topics and thank people for there replies.
Thanks
Mike
Thanks
Mike
I don't know about the reasoning for the OP's asking the question, but I think it is a valid topic of discussion.
My problem is with any Joe-Schmoe installing the conduit without being qualified. If the installer is trained in the proper installation of conduit for electrical use, and properly licensed, and the job is subject to inspection, then I don't care if they put it in or not. But that is not quite what the OP said.There is no need for electricians, or plumbers or HVAC guys as long at the installer of the systems involved has the proper training and licenses.
Granted the OP wanted an electrician to supervise but as long as the installer was properly licensed and qualified to install conduit for electrical use then that should be OK....it it is merely tubing and does not require supervision of a licensed electrician or an electrical inspection.
As long as it is not Handy-Andy, then any properly qualified and licensed contractor would do.I am really having a hard time coming up with good reason why the state should force that company to use an electrical contractor for that work.
I have to agree, it is a good topic of discussion and one that I have not seen beat to death already.
Back on topic ...
Consider you are a company that would like fiber optic cable installed in your facility, you would like it installed in EMT for your own reasons.
Who decided fiber optic is electrical work? Who decided non-conductive fiber optic cable should be covered in the NEC?
My gut says it was decided by people with self serving interests and not public safety.
Back on topic ...
90.1(A):Remember that the PRIMARY role of the NFPA(NEC) is fire prevention and control. Since the fire propagation issues of a fiber is most similar to cable and conductor parameters and the installation method as well, there is really no other sections of the NFPA where this would fit. Not to mention that the requisite experience and expertise exist within the panels and through the harmonization process a comprehensive process can be expected without the need for re-inventing the wheel.
(A) Practical Safeguarding. The purpose of this Code is the practical safeguarding of persons and property from hazards arising from the use of electricity.
90.1(A):
Where is the hazards from the use of electricity when talking about fiber optic?
Many other items that are not electrical could have similar fire propagation issues also.
