Jim W in Tampa
- Tampa Florida
Nothing in nec says we need prints,inspections or permits.
Jim W in Tampa said:Nothing in nec says we need prints,inspections or permits.
tallgirl said:And don't no one tell me I have no business spending other people's money!
tallgirl said:Having been around GC's my entire life (no, really -- my parents were the GC's for the house I was born in ...), I
Jim W in Tampa said:Fact is many houses are permitted with generic receptacles and lights on print to get the permit.In reality the owner often walks with the electrician and tells him/her what they really want.Millions are wired with no print in hand that comes close to what they got.Your lucky you even got a print.
By now i hope you relocated it to the bathroom LOLtallgirl said:They left the print in the hall closet by mistake. I, uh, BORROWED it.
job i'm doing now.........the print changes daily.nice thing is that it is 44 ft from the railroad tracks. 6 story tall. hope the rich like trains....lolJim W in Tampa said:Fact is many houses are permitted with generic receptacles and lights on print to get the permit.In reality the owner often walks with the electrician and tells him/her what they really want.Millions are wired with no print in hand that comes close to what they got.Your lucky you even got a print.
dingokangaroo said:job i'm doing now.........the print changes daily.nice thing is that it is 44 ft from the railroad tracks. 6 story tall. hope the rich like trains....lol
Lighting Outlet An outlet intended for the direct connection of a lamp holder, a luminaire (lighting fixture) or a pendent cord terminating in a lamp holder.
Receptacle Outlet An outlet where one or more receptacles are installed.
This is like driving a car through a single lane, one-way tunnel that has a sweeping right hand turn in it.roger said:Al, that is the key. it is the "Building Code" that requires illumination, that has never been disputed in this thread.al hildenbrand said:In my area it is the Building Code that requires illumination. Could be done with gas light, kerosene, chemical luminescence, but if the only thing in the room is an electrical lighting outlet. . .then there has to be a luminaire.
As far as an electrical inspector red tagging a dwelling unit for the lack of fixtures using the NEC as back up for the red tag, he/she is mistaken
In post # 10 pjg references my post and the citation I cut and pasted from Article 100 Definitions.pjg said:The code section cited reads "intended for " not "shall be installed".
david said:The addition of the blank cover would define the box as a junction not an outlet.
How does a cover change the "intended use"? The box and its wires are still intended to support and supply a light fixture.The definition of lighting outlet as given intended for connection of, as soon as you complete the work blanking off the box you have changed the intended use.
al hildenbrand said:All these flat closed statements that the NEC doesn't require the luminaire is like saying the turn signal tells which way my car is traveling.
How does the wall switch show, at final, that a luminaire will be installed some day, as opposed to a paddlefan that is incapable of ever having a light kit installed?iwire said:The fact that at least one wall switch controls that outlet further shows it is intended to be a lighting outlet.
Note, in my example, the turn signal is left on after the turn.iwire said:It does tell us what you intend to do...or at least we hope its what you intend to do.
