Wire-Smith
- United States
i haven't read all of the posts but just to through a wrench in, lobster aquariums are probably salt water
What? Rigged! But it is a you tube video...gospel.:angel:
We do not need no stinking education, math, and science to cloud up its validity, I saw it on the internet....
Earlier you said:
“I feel a little bad like I'm teasing a kitten”
Don’t, he deserves it IMO.
I personally do not like YouTube...
Then quit posting links to them and trying to make a point.
Non verifiable source. Worthless.
He was advocating putting a grounded probe in the tank, which will create create massive gradients in the tank should the GFCI fail.
salt water probably won't have massive gradients at 120 volt supply
I have no other real world examples.
But seriously- they give you a general idea of what is being discussed.
FWIW, Voltage gradients in salt water as less than that of fresh water.
likely more imo
since Z is lower current will follow a shorter more direct path
gradient = v/L with v being the same in all cases
so gradient higher?
but I need to think about it
One piece of advice the plumber gave me was to not put eggshells in the garbage disposer, especially if your house is (like mine is) set back a ways from the street. They tend to settle out in the pipes and cause blockages. It makes sense since eggshells are essentially limestone.gotta flush them once a week
fill sink with hot water and some baking soda
pull drain plug
turn disposal on until sink is drained
Guns can run out of ammunition thoughYeah I figured. You brought a knife to a gun fight. Bad idea.
I know what is being discussed.
I think the bigger problem is grease being poured down drain, then increased amount of solids from the disposer to get hung up in the grease. Eggshells are abrasive if you get them to flow may actually do some cleaning along the way.One piece of advice the plumber gave me was to not put eggshells in the garbage disposer, especially if your house is (like mine is) set back a ways from the street. They tend to settle out in the pipes and cause blockages. It makes sense since eggshells are essentially limestone.
likely more imo
so gradient higher?
Better than having nothing.
