jumper
- 3 Hr 2 Min from Winged Horses
All this over a badly written sales ad.:slaphead:
good lord Jumper....~RJ~
lower
think of tap water compared to a copper wire
salt water is more conductive(like the copper wire)
talking voltage gradients here
saltwater is safer
So I said my part.....
About the lobster tank, correct. But again, the NEC shows that the concern in GFCIs was more about missing EGCs and less about water.
Clearly: If everything the is energized in and around the lobster tank has an EGC I believe IMO there is no risk.
The biggest grease problem is when someone tries to flush grease down with hot water instead of grinding it up into tiny globules running cold water. It will cool and harden down the pipes a waysThe problem with eggshell fragments is that they are heavier (denser) than water and tend to settle out of the stream as it flows away from the house. Grease is a problem, too, of course.
Wow.....![]()
I agree. And in this whole debate the NEC clearly gives examples- or lines of thinking showing the concern is missing EGCs more than water.
Guns can run out of ammunition though
I think the bigger problem is grease being poured down drain, then increased amount of solids from the disposer to get hung up in the grease. Eggshells are abrasive if you get them to flow may actually do some cleaning along the way.
wrong
it is safer even with an egc
and all nec locations involve water/moisture
wrong, unless the egc is in the tank
and even then if the tanknis energized and the person is in parallel the gfci is safer
no one EVER used fake or rigged videos or hyperbole to increase view count and revenue
no such thing as click bait
you could not be more wrong
how do all these egc become 'missing'?
Again, in detail what do you see as being fake. All I hear are allegations of fakery, but inference behind the claim.
I agree both GFCI and EGC are safer than EGC alone. But if I had to choose between an EGC and GFCI only, I would choose an EGC.
Don't take this the wrong way- but you are thinking of GFCI like the public. Water, Water, wet, Water, Water, Water, moist, wet, Water, ect, ect. CMPs saw it as failed or missing EGCs.
FWIW I know of UK installations where again if you have a ground prove method (extra wire, solenoid activates the live conductors) you can again skip GFP.
You truly believe water will trip a breaker. It won't.
