rcarroll
- Fort Collins, Colorado
Yeah, it seems we need a little more info to help you.
Dennis Alwon said:Well, I have been assuming this is an electric radiant heater. Is it??? Different rule for radiant hot water heaters. Don't think the recep. rule applies there.
electricmanscott said:This is radiant heat in the floor. Doesn't mater if it's water, electric, or nuclear fusion. :grin:
That is one of the issues with cutting in a floor receptacle.
Being that it is in the floor technically it does not matter, code wise, for receptacle placement but if it were an electric unit I would not want the outlet on the far side of the heater for safety issues.
allenwayne said:To me if it is a loft then there is a ceiling below it.Drywall is allot easier to cut than a railing or remove flooring.
electricmanscott said:You should read the question.![]()
allenwayne said:I was just commenting it is allot easier to flap some drywall and have it repaired rather than channeling into wood.
iwire said:Perhaps the customer would like a receptacle here.:smile:
I wish.Dennis Alwon said:Your turn to counter if you wish.
The only thing that (A)(2)(1) does is to let us know a space under 2? wide does not count. At this point in the narrative, it is still talking about wall spaces in simple English terms. There is no formal definition, so we follow the generally accepted meaning. That would tell us that a ?wall space? is a space with a wall. It is not until (A)(2)(2) and (A)(2)(3) that we learn that the code authors want to include areas that are not commonly thought of as ?walls,? in their rules about receptacles in ?wall spaces.?Dennis Alwon said:(A)(2)(1) says any space 2' or more in width....
I do not exclude railing as a wall space. What I do is allow for the possibility that there will be some railings that are not wall space. Some cats (but not all cats) are household pets. Some railings (but not all railings) are fixed room dividers.Dennis Alwon said:210.52 (A)(2)(3) -- the space afforded by fixed room dividers such as free standing bar type counters or railings. This is an example of a room divider and to my mind does not exclude railings as a wall space.
No. But the question is not relevant. A railing is a wooden object that occupies space.Dennis Alwon said:Is a railing a space???
Agreed.Dennis Alwon said:This is a little bit like the OCP in closets where it says places like clothes closets..... At least a similar argument.
