growler
- Atlanta,GA
Actually, I believe that the FDs prefer the more expensive cheap brass locks that are labelled as having a "frangible shackle". (The shackle is made of cast iron and has narrowed spots to concentrate the stress.) That way you do not even have to bend the brass. You can also use a pry bar on them.
That sounds even better and I will look into those.
