Robert Merritt
New member
- Nashville, NC
We had an incident at my work place where a contractor wired a plug incorrectly. The equipment grounding conductor was crossed with a phase conductor, inadvertently energizing the mobile work trailer. The contractor placed his hand on the trailer disconnect and was held there until the power was removed by manually opening the supply breaker. In response to this event it was determined that had a ground rod been installed at the trailer bonding it to ground, that the contractor would not have received a shock. After watching Mikes video on grounding and bonding, I believe this is not the cause due to the fact that without the low impedance path back to the power source on the equipment grounding conductor the trailer would have remained energized even with the ground rod installed.
Could you please respond with an answer as to if installing the ground rod would have been any protection preventing the contractor from getting shocked? Also, now all trailers that come on site are required to be bonded to ground, is this giving a false sense of security against receiving an electric shock?
