brian john
- Leesburg, VA
I looked at a site yesterday that has experienced some issues with several motors. This is a new facility (less than 2 years old), the distribution is with cable tray utilizing an approved multi-conductor cable. The installing contractor did not do the prettiest job with the install. It was reported by another firm that there is a ground current current (I have not seen the report as of yet). They attempted to straighten out the cables and the measured level of ground current was reduced.
The issue that prompted the first investigation was the loose of 10 motors, the rewind shop said the motors had pitting of the bearings and the winding had pinholes in the insulation. These motors are controlled by VFD's.
I do not believe this is a grounding issue problem, though we are going to look at what may be causing some of the remaining ground current.
I think the pitting and insulation damage is a different issue and I thought I read here about pitted bearings and insulation issues due to some VFD issues?
