Laundry rooms must have GFICs, but if laundry rooms contain only washer, dryer and refrigerator, not laundry sink - this is the commercial facilities where I work and have 15 utilities room - will I need to replace the existing for the GFICs? What about the arc faults?
And if it is non dwelling application - neither GFCI or AFCI is required for the area described. Not too much there that likely needs brought up to code unless it is older then dirt.If you adding a new circuit , I would think it should be brought up to code.
Gosh I love this forum! Free schooling! Thanks!
Welcome to the forums.
A word of advice - title your threads with a logical, relavent title.
Something along the lines of "GFCI & AFCI requirements in commercial laundry" may get you better results.
