hbiss
EC, New York NEC: 2017
- Little Falls, New York NEC: 2017
- EC
Not berating anybody. This is as basic as basic gets. A receptacle has a brass and a silver screw. Because of your TRAINING you know that the white wire lands on the silver screw. The hot goes on the brass or black. You didn't have to read the instructions on the box did you? A homeowner or DIY would, why is that?
A telephone jack will either have the positions color coded or the wires going to the screws will be red/green/black/yellow. If you were trained properly you would know what the standard colors are for tip and ring and what the first pair, second pair, etc. is. Once you know that you should have no problem terminating the conductors properly even if they don't correspond to the colors on the jack.
-Hal
-Hal
