bobby ocampo
nakulak said:imo the importance of earthing the neutral is to provide the utility with a return path in the event of a bolted fault before the main.
What do you mean by a bolted fault? Is it line-to-line fault? Is line to ground fault a bolted fault for you?
nakulak said:(of course, if the utility wasn't so cheap, providing a separate grounding conductor would alleviate using the earth and probably save lives as well, since the earth path is not so hot)
What do you mean if earth is not so hot?
