bobby ocampo
jim dungar said:If the current is taking any unintended path it is a fault. Lets say that you have a 3-wire system with a conductor touching a metallic raceway.
If the system is bonded to the raceway, but not to ground. Any fault to the raceway will be sensed as an unintended current flow, ground (dirt) is not necessary.
How do you reduce hazard of electric shock in an UNGROUNDED AND HRG SYSTEM with a single line-to-ground energizing a metal piece of equipment?
jim dungar said:If the 3-wire system is not bonded then there is no fault;the first connection to the raceway simply creates a bonding path.
Sir please clarify what you mean in this comment.
